TheGrumpyGent
Dec 29, 2021Tutor
Port Setup for Orbi Pro VLANs
Hi everyone, hoping you can help me out a bit. I'm not sure what I'm doing wrong with setup, but I can't get two VLANs through a single trunk port on the SXK80's satellite. I have an 8 port managed...
TheGrumpyGent
Jan 05, 2022Tutor
The SXS80 was connected to the GS108T directly, and the SXS80 is connected to the SXR80 wirelessly. I decided to just nix using the managed switch and picked up two unmanaged switches (with each connected to the SXS80, and each switch being for one VLAN each). Not exactly what I wanted but the use case is solved.
schumaku
Jan 06, 2022Guru - Experienced User
TheGrumpyGent this reads a litle bit dangerous to me, considering e.g. the spanning tree protocol (STP) runns outside of the VLANs.
