spookz's avatar
spookz
VLAN setup on an IP phone passthrough port
Hi All,
I am attempting to setup 2 VLANs, one carry VoIP traffic and the other to carry data.  My challenge is each workstation only has 1 ethernet drop, so I am going to need to use the passthrough port on the phones to the computer (ie. [Netgear JGS516PE] <--- Mitel Phone <--- Computer) and I'm wondering if there is a way to have the switch be able to properly segregate the traffic.  My understanding is that the phones can tag their own traffic, but obviously the computers cannot.  Any insight would be appreciated.
Thanks.
  • Hi Spookz,
    We have default VLAN 1 port Data Traffic. Since you will connect the PC behind VOIP phone, we need to create a second VLAN and tagged all ports for Voice VLAN and VLAN 1 (DATA) should be all untagged ports.
    Example: VLAN 1 (data) and VLAN 2 (Voice)
    Advanced 802.1Q VLAN should be set as "Enable".
    Mitel Phone,  please configure the VLAN ID to "2" instead of default.
  • schumaku's avatar
    schumaku
    You run the VoIP VLAN traffic tagged, the data VLAN untagged.
    • spookz's avatar
      spookz
      Thank you for the info. On the ports carrying these types of traffic, do I flag them as tagged or untagged on the switch?
      • Nodism1125's avatar
        Nodism1125
        NETGEAR Expert
        Hi Spookz,
ProSupport for Business
