dragde0991's avatar
dragde0991
C3700 VPN Passthrough
I am trying to run the hotfix for vpn passthrough on the C3700-100NAS but keep receiving the error "multiple logins detected ret= 302". I am on Win7, router firmware version V2.02.17. I have reset my router password to password (even tried setting my wifi password to password). Any suggestions? Thanks!
  • vkdelta's avatar
    vkdelta
    Sep 17, 2018
    there is no such feature on any of Cable gateways. Hotfix was for VPN passthrough issue.
      • vkdelta's avatar
        vkdelta
        NETGEAR Employee Retired
        you dont have to run the hotfix for this FW. It was for very old FW.
        Issue was with VPN passthrough and it works ok on 2.x.x FW.
