dragde0991
Sep 10, 2018Aspirant
C3700 VPN Passthrough
I am trying to run the hotfix for vpn passthrough on the C3700-100NAS but keep receiving the error "multiple logins detected ret= 302". I am on Win7, router firmware version V2.02.17. I have reset my...
- Sep 17, 2018
there is no such feature on any of Cable gateways. Hotfix was for VPN passthrough issue.
vkdelta
Sep 16, 2018NETGEAR Employee Retired
which FW are you on?
dragde0991
Sep 17, 2018Aspirant
FW V2.02.17... thanks!
- vkdeltaSep 17, 2018NETGEAR Employee Retired
you dont have to run the hotfix for this FW. It was for very old FW.
Issue was with VPN passthrough and it works ok on 2.x.x FW.
forgot to ask you. what issue are you facing which you are trying to fix via hotfix?
- dragde0991Sep 17, 2018Aspirant
I wanted to enable expressVPN directly on my router but I do not have the VPN options anywhere in the netgear genie settings
