spookz
Dec 27, 2018Aspirant
VLAN setup on an IP phone passthrough port
Hi All,
I am attempting to setup 2 VLANs, one carry VoIP traffic and the other to carry data. My challenge is each workstation only has 1 ethernet drop, so I am going to need to use the passth...
- Dec 28, 2018
Hi Spookz,
We have default VLAN 1 port Data Traffic. Since you will connect the PC behind VOIP phone, we need to create a second VLAN and tagged all ports for Voice VLAN and VLAN 1 (DATA) should be all untagged ports.
Example: VLAN 1 (data) and VLAN 2 (Voice)
Advanced 802.1Q VLAN should be set as "Enable".
Mitel Phone, please configure the VLAN ID to "2" instead of default.
schumaku
Dec 28, 2018Guru - Experienced User
You run the VoIP VLAN traffic tagged, the data VLAN untagged.
- spookzDec 28, 2018AspirantThank you for the info. On the ports carrying these types of traffic, do I flag them as tagged or untagged on the switch?
- Nodism1125Dec 28, 2018NETGEAR Expert
Hi Spookz,
Got it, I appreciate the clarification. If I set all the ports to untagged and have the phone tag traffic for VLAN2 (as in your example), I can then setup the router to handle VLAN2 traffic on the port coming from the switch accordingly (DHCP, QoS, etc.), correct?
Thanks again, I'm sure these are basic questions I have just not done this previously.
