HugoGreefhorst
Jul 01, 2024Follower
Problem finding IP adress
The 'house' Wifi works great, but on the guest network, it is impossible to log in. The response is: can not get IP adress. Do you know how to solve it?
CrimpOn
Jul 01, 2024Guru - Experienced User
Would help to know more about the problem.
- Is it only one device that cannot log into the Guest WiFi?
(i.e. other devices are able to log in successfully. Have you tried other devices?) - What device is this that cannot get an IP address?
- Is Access Control enabled on this system?
(see page 84 of the User Manual)
https://www.downloads.netgear.com/files/GDC/SXK50/SXK50_UM_EN.pdf
