DaleDurnell's avatar
DaleDurnell
Problem with Orbi-68 as Access Point to Nighthawk
Until recently, I had a 4.58mbps DSL internet service. I tried to milk it for all it was worth with an RBR-750 with 2 satellites. Only rarely did I ever get both satellites to connect to the router. ...
  • KevinLiT's avatar
    Sep 12, 2022
    Hello DaleDurnell,
    Welcome to the NETGEAR Community!
    I understand that you are not able to access your SXR80.
    Please follow the steps below to resolve this issue:
    • Connect your SXR80 directly to your Ubiquiti Modem.
    • Then navigate to Orbilogin.com to verify you are able to log in to your SXR80 ( Do not change any settings at this time).
    • Next, add your SXR80 to your Insight app.
    • Then return your SXR80 to the desired location on your network.
    • Verify that you are still able to access the SXR80 from your Insight app and Orbilogin.com.
    • At this time navigate to Orbilogin.com to change your SXR80 from router mode to AP mode ( verify that you are able to connect via the Insight app).
    (FYI: The port that the SXR80 is connected to may need to be changed to Switchport mode access when SXR80 is in AP mode)
    Best,
    Kevin
    Community Team
ProSupport for Business
