SK2022
Feb 26, 2022Tutor
Nighthawk X6 R8000 Problems
After the latest firmware update a couple of months ago (Firmware Version
V1.0.4.76_10.1.82) I sharted having two major problems with the router:
1. Every other day the DNS breaks down, and I have to restart the router get the internet working again. This is the most troubling issue, impacting work meetings and such at the worst times.
2. Circle app does not load the visited sites for parental control any more.
Everything was working fine prior to the firware update. I have seen some other posts on both these problems, but no solutions or answers from Netgear so far. We cannot keep going with these problems. Just checking for the latest info from Netgear, or suggestions from commpunity, to decide it's time to move on from Netgear products for good.
v.62 seems to be the best version for now.
Hasselby wrote:
Been around 48 hours since downgrading the firmware...zero issues. I did not see my DNS issue recurring again through multiple computers at home. I had to refresh multiple times whenever I loaded a new webpage or add a new tab, but everything is smooth sailing right now.
I'm on v62 with my R8000 now...working ok. Might revert back to this version.
- SK2022Tutor
Thanks for responding. Cable Modem is Netgear CM1000 running Firmware Version
V7.01.01.I have tried rest of Circle, but not the full factory reset of the router. Because, the reset didn't fix the problem for any of the other users who tried that. So, I'd prefer not to do that unless there is definite proof or guidance from Netgear for doing that to fix the issue.
I'll see if I can find the older firware to downgrade if there is no other option.
Try the reset and setup from scratch. I would try using the router with out Circle enabled first to see if any problems appear.
Try enabling IPv6 on the router for DNS issues.
I would power OFF the modem for 1 minute then back ON as well.
Then try re-enabling Circle later on.
For issues with Circle, Netgear has set up a community forum specifically for the Circle product. Most of the people who watch that forum are more likely to have experience with Circle product. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
- SVKVAspirant
I am a few fireware updates behind. I am not able to log onto routerlogin.net or .com to do a firmware update. Can someone please help me????
Why not? What happens when you try?
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem. The firmware version also helps.You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)They are there for a good reason.
