DaleDurnell
Sep 06, 2022Aspirant
Problem with Orbi-68 as Access Point to Nighthawk
Until recently, I had a 4.58mbps DSL internet service. I tried to milk it for all it was worth with an RBR-750 with 2 satellites. Only rarely did I ever get both satellites to connect to the router. ...
- Sep 12, 2022
Hello DaleDurnell,
Welcome to the NETGEAR Community!
I understand that you are not able to access your SXR80.
Please follow the steps below to resolve this issue:
- Connect your SXR80 directly to your Ubiquiti Modem.
- Then navigate to Orbilogin.com to verify you are able to log in to your SXR80 ( Do not change any settings at this time).
- Next, add your SXR80 to your Insight app.
- Then return your SXR80 to the desired location on your network.
- Verify that you are still able to access the SXR80 from your Insight app and Orbilogin.com.
- At this time navigate to Orbilogin.com to change your SXR80 from router mode to AP mode ( verify that you are able to connect via the Insight app).
(FYI: The port that the SXR80 is connected to may need to be changed to Switchport mode access when SXR80 is in AP mode)
Best,
Kevin
Community Team
KevinLiT
Sep 12, 2022NETGEAR Moderator
Hello DaleDurnell,
Best,
Kevin
Community Team
DaleDurnell
Sep 12, 2022Aspirant
Thank you ever so much -- that's one step I have not tried. I tried directly connecting my computer to the Orbi68, but that hasn't worked. It will be quite easy to connect my Orbi68 to my Ubiquiti modem and bypass my Nighthawk until I get access to my Orbi.
Thanks again, so very much
Dale
