racoon
Jan 22, 2022Aspirant
Problem with the configuration of the vlan id on netgear orbi Orbi Pro 6 (SRX80) and slow internet
I have connected the orbi router to a ftth ont with 1gbps down and 100mbps upload, the connection use ppoe and a vlan id which i have configured on the orbi router. The router connects properly to in...
DaneA
Jan 31, 2022NETGEAR Employee Retired
Please try to update the firmware of your SXR80 to the latest version which is v3.3.0.124 then observe if the same problem will occur. You can download firmware v3.3.0.124 here.
Make sure to check if the PC/s hardwired to the SXR80 is getting a valid IP address.
DaneA
NETGEAR Community Team
