Hardie's avatar
Hardie
Question: Works Orbi Pro setup with a Netgear WBC502
Hi,
is a Ori Pro setup compatible with a Netgear WBC502 and if so, whats the best way to setup?
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hardie,
    Welcome to our community! :)
    AirBridge WBC502 is not compatible with the Orbi Pro if you are trying to add the WBC502 into the mesh. It will still provide its own SSID and will just see as an access point. May I know what do you want to achieve here?
    John
    NETGEAR Community Team
ProSupport for Business
