Lsands
Jun 12, 2021Tutor
Airbridge WBC502 slow upload speed
I have 4 airbridbges setup. 3 of the 4 function perfectly and have a download speed of ~95mbps and upload of 12 mbps. The 4th airbridge is my problem. it's configured the same as the other 502's but I'm clocking a download of ~90mbps and an upload of <200k.
any ideas why this is happening and how to correct it?
TYA ...
configuration:
DHCP Enabled for IP address, DNS, gateway
STP is Disabled
Wireless Mode: 11ac
Channel: 149
Channel Width: 20 Mhz
Transmission power: Auto (22 dBm)
Distance: 1
Antenna Alignment is excellent; TX power is 22 dBm, signal strength is -46dBm
I found the issue ... RJ45 connector was dirty.
thx
- DaneANETGEAR Employee Retired
Welcome to the community! :)
Kindly describe how and where are the 4 WBC502 are deployed. Also, post an image of your detailed network diagram on how is everything connected.
What is the current firmware version of all WBC502?
DaneA
NETGEAR Community Team- LsandsTutor
thx
