tilda
Nov 27, 2020Aspirant
AirBridge Set up
Purchased the 2 pack AirBridge. Distance between source AirBridge (my house), and target AirBridge (a workshop) is about 500 ft.
Have not set anything up yet.
Do I need to connect something like a NETGEAR AC2000 Dual Band Wireless Access Point (WAC124) to the target AirBridge with Ethernet in order to get wifi to computers and iPads at that target location?
Note: the WiFi source is generated by an AT&T modem/router in the house.
Thanks
The AirBridge pair does only establish the connection, it does not have a wireless access point to connect wireless clients at the far location. The only exception is a short range 2.4 GHz radio for the local management of the device only. Said that: Yes, you need an additional access point.
- tildaAspirant
Thanks for the clarification.
So, could I use a NETGEAR Wireless Access Point (WAC510) and connect it with Ethernet directly to the target AirBridge's Power Adapter?Would that just extend the home network or would I be creating a whole new network at the target location?
For adding a Netgear WAC5xx or WAX6xx you need either a power supply or a PoEPoE+ switch. Be Ethernet yes, the AirBridge's Power Adapter is for the AirBridge unit only.
