tilda
Nov 27, 2020Aspirant
AirBridge Set up
Purchased the 2 pack AirBridge. Distance between source AirBridge (my house), and target AirBridge (a workshop) is about 500 ft. Have not set anything up yet. Do I need to connect something like a ...
- Nov 28, 2020
The AirBridge pair does only establish the connection, it does not have a wireless access point to connect wireless clients at the far location. The only exception is a short range 2.4 GHz radio for the local management of the device only. Said that: Yes, you need an additional access point.
schumaku
Nov 28, 2020Guru - Experienced User
tilda
Nov 28, 2020Aspirant
Thanks for the clarification.
So, could I use a NETGEAR Wireless Access Point (WAC510) and connect it with Ethernet directly to the target AirBridge's Power Adapter?
Would that just extend the home network or would I be creating a whole new network at the target location?
- schumakuNov 29, 2020Guru - Experienced User
For adding a Netgear WAC5xx or WAX6xx you need either a power supply or a PoEPoE+ switch. Be Ethernet yes, the AirBridge's Power Adapter is for the AirBridge unit only.
- hnagaraju1Dec 06, 2020Guide
Network1=====WBC502(root) ~~~~~~500 meters-~~AirbBridge link~~~~~~~~ WBC502(Satellite)====Network2
you can use any of Access points.
WAC500 series, (11 AC)
WAC100 series (11AC)
WAX200 series (`11AX)
WAX600 series (11AX)
to server wireless clients in Network2 side. 500 and 600 series can be powered on with power adaptor or Poe/Poe+ switches.
