NemoNeil
Apr 29, 2022Guide
RDP over Difrerent VLAN issue
I have SXK80 with 2 Sattelites my configuration is as follows regarding VLAN: Computer A is on VLAN "O20" with Client Isolation Enabled and Network Isolation Enabled Computer B is on VLAN "O...
NemoNeil
May 03, 2022Guide
Hey Bruce
I cannot Ping the machine
Heres simplified setup:
Port 1 = Connected to ISP Modem = VLAN ID 1 (Trunk Mode)
Port 2 = Connected to an unmanaged 4 port Switch = VLAN ID 2 (Trunk Mode)
Port 3 = Connected to PC 1 = VLAN ID 3 (Access Mode) Client Isolation=On Network Isolation=On
Port 4 = Connected to PC 2 = VLAN ID 4 (Access Mode) Client Isolation=Off Network Isolation=Off
From PC 2 I want to able to RDP to PC 1. As i understand Network Isolation is off on VLAN 4, so should be able to connect to VLAN 3?
I have RDP enabled on PC 1. Not sure what else i can check?
hnagaraju
May 03, 2022NETGEAR Employee Retired
If you have separate VLANs, then you need configure static routes.
In SRK80, the solution will be to enable different wireless on same VLAN and enable client isolation for rest of the devices, with just these two clients allowed to communicate.
We will be adding mDNS gateway that will allow some know protocols to be routed across VLANs.
Please reach out to BruceGuo via messaging to get a pre-release firmware if you want to try it out.
