NemoNeil
Apr 29, 2022Guide
RDP over Difrerent VLAN issue
I have SXK80 with 2 Sattelites my configuration is as follows regarding VLAN: Computer A is on VLAN "O20" with Client Isolation Enabled and Network Isolation Enabled Computer B is on VLAN "O...
BruceGuo
May 09, 2022NETGEAR Expert
I thought having Network Isolation on VLAN3 means it cannot communitcate out to other VLANs?
=> Ans: Yes
so in a scenario where VLAN3 was compromised, it cannot infect other VLANs.? same goes with Client Isolation, if enabled it cannot infect other client within the same VLAN
=> Ans: Yes
Having VLAN4 Netowrk Isolation off mean it should be able to talk to other VLANs in this case VLAN3
=> Ans: No. It means other VLANs can talk to VLAN4
So having disabled the Cliant Isolation and Netowrk Isolation OFF on VLAN 3 and also on VLAN 4 allows me to RDP between PC 2 to PC 1. But doesnt this defeat the purpose of VLAN as now the network communcication between both VLANs are now open?
If one VLAN was compromised, the other VLAN surely will get infected?
=> Ans: Let me explain more. The desing of VLAN is to separate broadcast domain. Layer 2 packets will be only active in within a VLAN. So, if a PC is comprised and then it is flooding,
other VLANs would not be impacted. But, it doens't prevent layer 3 attacks. The infected PC can still communicate across VLANs via https, smtp, etc. The design of network isolation enhances the security. It "compeletely" isolates inter-VLAN traffic.
Why can i not only enable RDP ports between the 2 VLANs so not everything is exposed?
=> Ans: we don't have this feature now. The design will be more complicated. The can be future work and will forward to PLM to decide when we can implement it.
NemoNeil
May 10, 2022Guide
Hi BruceGuo
Thanks for the explanations and gives a good understanding around how the Orbi Network Isolation works
I would be really intrested in seeing inter-vlan integration. being a £1k device, its very similar to my previous home user router which was around £100 and yes the Orbi has some nice advantages, but not feature rich which im still yet to see. comparing to somthing like Asus home router which has a whole vast of settings, i would expect this to be better. Performance wise i cant fault the Orbi, but really like to see what more can the Orbi offer.
Is there a beta version of firmware to be released with other tweaks and enhancements? when do major firmware updates are released?
Thanks
- hnagarajuMay 10, 2022NETGEAR Employee Retired
We have been releasing almost every 3 months for SXK80 with some new features and some enhancements to existing features.
If you need new features implemented. Please post it here and you can cross link to other threads too.
https://community.netgear.com/t5/Idea-Exchange-For-Business/idb-p/idea-exchange-for-business
Getting UpVotes to new ideas on this forum will catch the eyes of the PLMs.
Please keep your ideas coming in. cross vote for other people ideas that will help general deployments.
Thank you,
Engineer.
