CHCarlos
Feb 25, 2024Guide
Firmware Version 4.3.2.100 BUG
Hi all
What's about this problem. I sink I have the same issue.
Is an update on the queue?
Kind regards
Carlos
- Apr 04, 2024
The 4.3.3.200 Release notes show
- Fixes an issue where the device that is connected on Ethernet to SXR80 or SXS80 does not come UP for approximately 30 seconds.
Could this be the DHCP issue or connection delay you experience?
schumaku
Apr 04, 2024Guru - Experienced User
CHCarlos
Apr 05, 2024Guide
Hi,
Many thanks for the new firmeware. It's solves all my problems.
Thank for your support!
Kind regards
Carlos
- FURRYe38Apr 05, 2024Guru - Experienced User
Enjoy. 📡
