Mstrbig
Feb 12, 2024Master
I can no longer log into SXK80 system using 192.168.1.1
I have always been able to login to 192.168.1.1, or any of the orbilogin methods. Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 1...
schumaku
Feb 12, 2024Guru - Experienced User
Wait - do you have https enabled on your Orbi Pro SXK80 system?
Or have probably the Facebook Wi-Fi portal for the guest WiFi network enabled and active? Wireless > Guest Portal (Orbi Pro WiFi 6 AX6000 Tri-band WiFi System (SXK80) User Manual, p.109 ff.)
The special 192.168.1.1 URLs you listed before are plain http only of course?
Mstrbig
Feb 12, 2024Master
No, but I'll try to access and double check.
