Mstrbig
Feb 12, 2024Master
I can no longer log into SXK80 system using 192.168.1.1
I have always been able to login to 192.168.1.1, or any of the orbilogin methods. Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 1...
quagmire1
Feb 13, 2024Luminary
Is this the actual error message?
ERR_SSL_KEY_USAGE_INCOMPATIBLE
If so, this is a known issue. There are several threads here discussing it. Workaround is to use Firefox. We're waiting for Netgear to fix this - it's ultimately on them.
DavidGo
Feb 14, 2024NETGEAR Expert
Hi all,
The issue is confirmed and we now have a patch firmware to fix it. After installing the patch firmware a factory reset is required.
If anyone would like to install the patch firmware please send me a PM.
Thanks
DavidGo
- schumakuFeb 14, 2024Guru - Experienced User
Hello DavidGo
Lost as before.... what was relly fixed now?
We're supposed being able to login to the Web UI as before?
A new self.signed certificate deployed so the ERR_SSL_KEY_USAGE_INCOMPATIBLE error does no longer appear?
Can a factory reset, thus new installed SXKn0 be added again to Insight, so the settings are back?
Thank you
-Kurt
- DavidGoFeb 15, 2024NETGEAR Expert
Hi schumaku
In the patch firmware it is just fixing the issue where the SXK80 is not allowing login to the local admin page, but everything else is working as normal.
After installing the patch firmware and doing the factory reset the ERR_SSL_KEY_USAGE_INCOMPATIBLE error no longer appears.
If the device is added in Insight, it should come back online in Insight and sync the config once Internet access is restored to the SXR80.
Thanks
DavidGo
- MstrbigFeb 15, 2024Master
The patch did not work for me in the latest version of Edge in Windows 11.
I was able to access my CP with Firefox and install the patch. I confirmed the router and both satellites installed the patch. Unfortunately, there was No change in Edge after factory reset.
- MJDSFeb 15, 2024Aspirant
Hello DavidGo,
I have the same problem with my router.
Is there a new firmware update for my router.
At this moment there isn't one.
- MewohkieMar 03, 2024Tutor
Is this the sxr80-v4.3.2.1001356-signed firmware? I was sent a copy that I installed but I am still seeing the SSL Certificate error when trying to log into the router on edge or chrome.
- MstrbigMar 03, 2024Master
I still see the certificate error message as well, but I am able to hit continue and log in, where before I would get a missing page.
- KurtpfostMar 10, 2024Aspirant
I keep getting this error message when I try to log into my SXR80 Router "
ERR SSL KEY USAGE INCOMPATIBLE"
I use Password Keeper so I know I am using the same username and password, it has worked ok since I purchased my router using my HP Desktop computer. All of the help messages I have found on the internet has been very confusing for me. I am computer literate as I have been using them since 1983, started with a Tandy 1000 with dual 5-1/4 floppy's.
My router information is:
WIFI Network Name: ORBI54
Network Key Password: Sorry Did Not Post this
Serial Number 6KW6215FA6E69
MAC: C89E43AB6AD2
