Mstrbig
Feb 12, 2024Master
I can no longer log into SXK80 system using 192.168.1.1
I have always been able to login to 192.168.1.1, or any of the orbilogin methods. Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 1...
DavidGo
Feb 15, 2024NETGEAR Expert
Hi schumaku
In the patch firmware it is just fixing the issue where the SXK80 is not allowing login to the local admin page, but everything else is working as normal.
After installing the patch firmware and doing the factory reset the ERR_SSL_KEY_USAGE_INCOMPATIBLE error no longer appears.
If the device is added in Insight, it should come back online in Insight and sync the config once Internet access is restored to the SXR80.
Thanks
DavidGo
Mstrbig
Feb 15, 2024Master
The patch did not work for me in the latest version of Edge in Windows 11.
I was able to access my CP with Firefox and install the patch. I confirmed the router and both satellites installed the patch. Unfortunately, there was No change in Edge after factory reset.
- TechdeskxyFeb 15, 2024Aspirant
Did you push the firmware update through the app or the web portal?
- MstrbigFeb 15, 2024Master
Web Portal
But! I have an update. After attempting and failing following the instructions, I went back to Firefox, accessed my Orbi router and backed up and erased the routers settings bringing it back to factory settings. Then I restored it from my backup. I did not reboot or anything. I went to the latest update of Edge and now I can access the router at he normal ip 192.168.1.1 with no error. I don't know why the factory reset did not work, but for me the above method completed the fix.
