chadonmac
Jan 09, 2021Initiate
Orbi firmware V2.6.0.108 no longer allows Orbi App connection
I let the Orbi insight app update my router and satelites to V2.6.0.108 and now i am unable to connect to my network through the local Orbi App. I have tried all troubleshooting steps(I could connec...
DJHazmat
Feb 04, 2021Star
Hey Raghu, thanks for the offer. Unfortunately, I downgraded the firmware on the SRR60, SRS60 and the RBY50 back to 2.5.4.104 which was the last firmware where I didn't get constant drops. Everything for me is as stable as it ever was now. the issue I had with this fw version was that I had to reboot the router every couple of days. So I can live with that instead of getting connections dropped throughout the day.
Oh, and BTW, my Genie Aladdin Connect started working again after downgrading. I'm going to open a thread elsewhere for that.
cecltd
Feb 05, 2021Tutor
It's very weired to fix the problem by downgrading the firmware.
So what is the point of publishing a new firmware? Not to fix problem but to create problems and shows you the old firmware is better?
- dirFeb 05, 2021ApprenticeI’m pretty sure that the reason they’ve updated the firmware is to move customers onto their new business model. It’s not about fixing and adding features; it’s about forcing customers to use a changed service that brings in new revenue streams.
- TonytonytonyFeb 05, 2021TutorTried the insight app and did not like it with the new firmware upgrade, downgrade back down.
Now, let’s say I upgrade my firmware back to 2.6.0.108 and keep it.. I lose the orbi app... So, now I use Insight and I only have 1 month free? Then I have to pay to keep using the app? Doesn’t make sense or am I missing something?. is there another app I can use? What’s the point of buying an Orbi Pro? I noticed a new Orbi app update 3 days ago, does that fix the issue with using Pro on the new firmware? I don’t want to upgrade back to 2.6.0.108 to downgrade back again.- dirFeb 05, 2021ApprenticeWithout official word it’s hard to know for sure. All I can tell is that you’re correct- the latest firmware for the orbi pro disables access to the Orbi app and forces you to either use the Insight app or the web UI.
Insight will become a pay-to-use app in March. Do you either pay to use Insight or you can only access the Orbi pro configuration via the web UI.
