secdoc
Jul 10, 2023Aspirant
Orbi pro wifi 6 (SXK80) can't do separate vlans in ap mode
I have installed the Orbi Pro Wifi 6 systems and have them in AP mode. I tried following or using the below solution as the mechanism to take/use the existing VLANs on my network. https://communi...
schumaku
Jul 10, 2023Guru - Experienced User
Conclude, all the standard DHCP tasks are never forwarded accordingly to the appropriate VLAN when I get you right. Should not be a difficult thing for a software acceptance test 8-/
- DHCPDISCOVER: broadcast request to all DHCP in the network
- DHCPOFFER: answer to the DHCPDISCOVER
- DHCPREQUEST: from the client to the DHCP server, requesting IP or lease extension
- DHCPACK: acknowledged DHCP requests or DHCPINFORM requests
- DHCPNAK: refused DHCPREQUEST by the DHCP server
- DHCPDECLINE: ...
- DHCPRELEASE: ...
- DHCPINFORM: ...
BasuKhodanapur
Jul 11, 2023Apprentice
Hi secdoc ,
Please refere below community link it may help you to configure vlans and port configurations.
Thanks,
Basavaraj
- schumakuJul 11, 2023Guru - Experienced User
Dear BasuKhodanapur
As discussed and explained by the OP before, it appears the DHCP does not work when the data is flowing over the Orbi Pro 6 tagged VLAN, e.g. in the case it's configured as a trunk for the VLAN.in question.
-Kurt
- secdocJul 11, 2023Aspirant
oes th
BasuKhodanapur wrote:Hi secdoc ,
Thanks,
Basavaraj
Does the Native VLAN have to be VLAN 1?
- BasuKhodanapurJul 14, 2023Apprentice
Hi secdoc ,
Yes configure default management vlan1 as 1 and configure management port as a untagged port and other vlan ports as tagged port.
It will resolve the case.
Thanks,
Basavaraj
