secdoc
Jul 10, 2023Aspirant
Orbi pro wifi 6 (SXK80) can't do separate vlans in ap mode
I have installed the Orbi Pro Wifi 6 systems and have them in AP mode. I tried following or using the below solution as the mechanism to take/use the existing VLANs on my network. https://communi...
secdoc
Jul 11, 2023Aspirant
oes th
BasuKhodanapur wrote:Hi secdoc ,
Please refere below community link it may help you to configure vlans and port configurations.
Thanks,
Basavaraj
Does the Native VLAN have to be VLAN 1?
BasuKhodanapur
Jul 14, 2023Apprentice
Hi secdoc ,
Yes configure default management vlan1 as 1 and configure management port as a untagged port and other vlan ports as tagged port.
It will resolve the case.
Thanks,
Basavaraj
