timecode
Aug 12, 2022Guide
SXK80 Satellites turn pink as soon as I use VLAN tagged network
SXK80 in AP mode with 2 satellites (Latest firmware V4.2.1.120) - VLAN tags provided by pfsense router. (VLAN30 and VLAN50) - smart switches throughout (Trunked and tagged appropriately). VLAN setup...
- Jun 23, 2023
ETA for FW release is end of July.
timecode
Aug 20, 2022Guide
Hi DaneA,
Ok, have performed full factory reset on all units. Re-setup in AP mode which was auto detected.
I added one secondary wifi network with factory vlan flag (20). I left the factory vlans intact and did not add any others. There is no other changes. No changes to any of the port settings.
As soon as I join the secondary wifi network that is tagged with vlan, satellites turn pink and then network falls over.
Doing a simple ping to router/gateway shows as getting a response for a few replies and then nothing.
As soon as I disconnect from secondary wifi network and rejoin main wifi network satellites turn blue and network stability returns.
So no difference has occurred from full reset.
RaghuHR
Aug 20, 2022NETGEAR Expert
Hi timecode Could you please share the debug logs from both router and satellites?
Go to
https://<ip address of router/satellite>/debug.htm
and save debug logs when issue happens.
You can upload the debug logs into any cloud storage and send me PM to download the link.
Thanks,
Raghu
- timecodeAug 20, 2022Guide
Hi Raghu
PM Sent.
Cheers
- timecodeSep 21, 2022Guide
For anyone still following this, I am currently backwards and forwards with logs and testing.
Hopefully a result soon enough.
- MrJoshWOct 13, 2022NETGEAR Employee Retired
Hello,
I tried to re-create your issue but I am unable to get the results you are describing. Are you able to send me a topology map of your network layout? This will help me try to re-create a layout close to yours to see if I can re-create. Attached is the layout of my setup.
- timecodeOct 13, 2022Guide
Hello MrJoshW
Thanks for jumping in
Network topology attached. I have simplified everything to find this issue. The layout is pretty much the same as yours.
I also created a test environment where I used a separate router with different OS installed and connected directly to Orbi router to eliminate all other devices. Gave me the same result.
In the current setup shown, this is showing only the path for the Orbi. Things to note are - VLAN devices connected via Orbi or anywhere else on the network all receive correct IP's etc so the "path logic" would seem correct. Router has simple allow all rules at present. All switches attached are smart and also have correct RSTP values.
The devices connected to the Orbi Satellites do work for a short time (1 min max) then start to fail. I am using a simple ping test for this. The test involves 4 terminal windows consecutively running ping tests to - 1.1.1.1, 8.8.8.8, Gateway IP, Local Printer sitting on main LAN - nothing complicated.
My last round of testing was rather interesting as per below:
Macbook Pro (Mid 2014) - Wifi connected to SXRouter - ping test successful, no dropouts, no pink satellite. PASS
ACER Laptop (2021) (WIFI6) - Wifi connected to SXRouter - ping test successful, no dropouts, no pink satellite. PASS
Both together connected at same time to SXRouter - ping test successful, no dropouts, no pink satellite. PASS
##########################################################################################ACER Laptop (2021) (WIFI6) - Wifi connected to SXSat - ping test successful, no dropouts, no pink satellite. PASS
Macbook Pro (Mid 2014) - Wifi connected to SXSat - ping test fails, multiple dropouts, pink satellite - network fail. FAIL
Dell laptop E7250 (2015) - Wifi connected to SXSat - ping test fails, multiple dropouts, pink satellite - network fail. FAIL
Thinkpad Laptop X280 (2018) (WIFI5) - Wifi connected to SXSat - ping test fails, multiple dropouts, pink satellite - network fail. FAIL
So from this it might indicate that the router can handle older wifi standards but as soon as it connects to a satellite it fails.The ACER laptop is the only computer with WIF6 I have.
Once the Failing devices are removed from the network it recovers - pink light turns to blue and then off.
Can reach gateway on all counts and is actually one of the ping tests.
I don't think this is a very complicated scenario and would be common with many setups.
Any light you can shed on this would be awesome.
With thanks
Hello,
Based on your topology, question question. Are the satellites using wired or wireless backhaul to the Orbi router?
If the devices are wired backhaul, can you connect one using wireless backhaul and verify if you see the same issue?
They are wireless backhaul.
I can try the wired backhaul but will have to wait as it is in production use at present!
- timecodeOct 19, 2022Guide
Update: Confirmed issue with satellite sync when two or more satellites in use.
So now just have to wait for a fix in due course.
- hermesromerorDec 29, 2022Apprentice
- timecodeFeb 16, 2023Guide
Still awaiting an updated firmware.
- hermesromerorFeb 23, 2023Apprentice
