CR4's avatar
CR4
Guide
Jun 09, 2026
RBS50 satellite connect to RBR850 network?
I have been running RBR50 + 5 satellites for a while and it have been pretty solid.
i just picked up an RBR850 and 2 RBS850 satellites, but range is not quite enough for the whole house, I need an extra satellite.
I did a quick ‘chatgpt’ which suggested I could use the RBS50 to extend the range, saying that particular node would be slower, but it would at least give me the coverage.
Anyway, I tried a number of times to connect it,  without much success. On one occasion, I thought it had worked, but the SSID was still the factory default, not the same as the main mesh network. Although I could connect to it, it’s not really a solution
Am I wasting my time ? Do I need to fork out for another RBS850, or can anyone suggest other things I can try?
TIA
    yes.
    Here's the compatibility matrix:
    • https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
  • StephenB's avatar
    yes.
  • Thanks everyone for their input.
    i managed to pick up a 2 pack of RBR850/RBS850, so I added the satellite to my network, and all is well.
    I’ll keep the router as a spare for now.
    It’s a pity Netgear don’t make it easy to switch devices between router/satellite.
    I know there is a hack out there (I did it with an RBR50)
    The hardware seems identical.
  • CrimpOn's avatar
    CrimpOn
    Similar: yes.  Identical: No.  The router has a 2.5G WAN port which the satellite does not.  It might be interesting to speculate that loading satellite firmware on a router would simply mean that the 2.5G WAN port would be ignored.
