timecode
Aug 13, 2022Guide
SXK80 Satellites turn pink as soon as I use VLAN tagged network
SXK80 in AP mode with 2 satellites (Latest firmware V4.2.1.120) - VLAN tags provided by pfsense router. (VLAN30 and VLAN50) - smart switches throughout (Trunked and tagged appropriately). VLAN setup...
- Jun 23, 2023
ETA for FW release is end of July.
redeagle45
Jun 23, 2023Aspirant
I am concerned to see this as I was planning to upgrade to the SXK50 or SXK80 specifically to use as an AP with VLANs.
I use an Orbi RBK today as router and wifi because I did not know it lacked vlan support when originally purchased it. This is no longer acceptable with three people working at home and two of us having a fair amount of work specific hardware provided to us for use at home.
I will temporarily setup a pfsense router as I am familiar with it, but my company will be providing an SD-WAN device as the main router and will configure VLAN's to split my work domain from all the other stuff in the home. I like the brand and use several netgear switches also.
I can understand Netgear wanting to manage the whole pie, but if they are not working well as a pure AP, I need to look elsewhere. Any status update on this firmware fix becoming GA for all of these devices?
hnagaraju1
Aug 07, 2023Guide
Other than SXK80/50/30 that work in router as well as AP mode.
NETGEAR has multiple WAX6xx series of APs, WAX200 series of APs that support VLAN per SSID tagging.
depending on your usecase, one of these should fit well with the solution.
If you have PFsense router. Here are the options
PF-senserouter/gateway====Poe+Switch=====WAX6xxx. (WAX610/WAX620/WAX610Y etc). (supports wired/wireless backhauls. Easy to setup with Insight cloud UI. needs more skills to set up wireless backhauls via AP's local UI)
PF-senserouter/gateway=====Poe+Switch====WAX214v2/WAX220 (PoE APs, wired backhauls only)
PF-senserouter/gateway=========WAX202/206 (desktop APs, wired backhauls only)
PF-senserouter/gateway=========SXR80(in AP mode) (supports wired/wireless backhauls. easy to setup with locl UI)
- cmprmsdAug 17, 2023InitiateI'm looking for this beta release as well and would like to join the beta group of possible.
Same problems with AP mode and VLANs configured in combination with an OPNsense firewall.
Also I wonder if there will be an update to remove the need of a full router and satellite restart, when any VLAN is changed. This will disconnect all clients and satellites if the network configuration is not fully static. I'd expect this from a business product.
Thanks in advance! - MrJoshWAug 17, 2023NETGEAR Employee Retired
Hello,
Please send me a private message with your email and I can forward you the beta image.
