martendej
Aug 16, 2022Aspirant
SXR50 Tagged VLAN goup on WAN
Hello all, I would like to make a tagged VLAN group on the WAN port (ID 4 and 6, per requirement of ISP, 4 = IPTV and 6 = Internet). This would result in the eth0.4 and eth0.6 interfaces. I have ...
BruceGuo
Aug 17, 2022NETGEAR Expert
1. Assume port 1 is WAN. Port 2 is connected with IPTV device
2. Assign a profile with VID=6 to port 1.
3. Assign "IPTV" profile with VID=4 to port 2
So, internally Port 1 and Port 2 will be added to the same bridge. Other port will be in LAN bridge.
Check if that works.
martendej
Aug 17, 2022Aspirant
Ok, I will try to explain the ISP requirements as clearly as possible.
- Tagged traffic should only be used on the WAN port. From there, all traffic should be untagged.
- An IGMP proxy should be set up on the WAN port, where downstream = VLAN6 BUT upstream for certain IP ranges should be routed through VLAN4 with static routes. It should have alternate-subnet set to '0.0.0.0/0'.
- VLAN4 should use DHCP with option 60 set to 'IPTV_RG' and option 28 set to '192.168.1.255'. It should ask for a 'classless ip'.
- Nat should be enabled for traffic for ranges 213.75.112.0/21 and 217.166.0.0/16 between VLAN4 and the internal network.
Is this possible, albeit with some config modifications through telnet (which I have already enabled on the Orbi)?
A nice puzzle! đ
A nice puzzle! đ
