martendej
Aug 16, 2022Aspirant
SXR50 Tagged VLAN goup on WAN
Hello all, I would like to make a tagged VLAN group on the WAN port (ID 4 and 6, per requirement of ISP, 4 = IPTV and 6 = Internet). This would result in the eth0.4 and eth0.6 interfaces. I have ...
BruceGuo
Aug 17, 2022NETGEAR Expert
1. Assume port 1 is WAN. Port 2 is connected with IPTV device
2. Assign a profile with VID=6 to port 1.
3. Assign "IPTV" profile with VID=4 to port 2
So, internally Port 1 and Port 2 will be added to the same bridge. Other port will be in LAN bridge.
Check if that works.
martendej
Aug 17, 2022Aspirant
Assigning VLAN4 to port 2 will not work since the IPTV box should be in the same network as it also requires internet access. Furthermore the ISP does not allow bridged IPTV.
- BruceGuoAug 17, 2022NETGEAR Expert
Hi
We are internally discussing. If you have a network topology diagram, that would help us understand better. will get back to you.
Bruce
