Chippy_boy
Apr 19, 2025Aspirant
SXS80 only broadcasting Wireless1
Hi - Hope someone can help? I have an SXR80 router, SXS80 satellite and SXS30 satellite. I have been using the SXR80 for quite a while but am only now adding the SXS80 and SXS30 to the mesh. I h...
quagmire1
Apr 20, 2025Luminary
Are you using wired backhaul for the SXS30? If not, try removing the SXS30 and see if that fixes things.
Chippy_boy
Apr 21, 2025Aspirant
Thanks both.
Wireless backhaul. Interesting idea about removing the SXS30 - I wonder if that being incompatible might be restricting the SXS80 in some way - I'll try it.
And yes, I guess a full reset is perhaps going to be needed. I have been trying to avoid that since my network is "working" - after a fashion - and from experience, the full reset will inevitably mean that something else breaks!
- FURRYe38Apr 28, 2025Guru - Experienced User
Any progress on this?
