paul_pl
Sep 03, 2021Aspirant
VPN accounts in RBK50, does they exist?
I just installed in our new office RBK50 and I'm very excited about the bandwitdths I get using wifi. I struggle though with vpn. I and my workers need to have remote access to office server (qnap). ...
schumaku
Sep 03, 2021Guru - Experienced User
It's even worse the Netgear VPN does require the admin credentials.
Alternate approach would be looking into the QNAP QTS options for various VPNs -> How to set up and use QVPN? QBelt, L2TP/IPsec (PSK), OpenVPN and for the sake of it also PPTP is available. The nice part is that you can use the QNAP authentication you need for the data access on the shared folder anyway - so much less duplicated management.
-Kurt
paul_pl
Unfortunately our model is quite old and although there is a VPN option it works not very well. in case you want download or upload bigger files like 50 or 100 MB there are constant break ups. I do use qnap VPN at home with my newer model of qnap and it works well. so currently I am looking for the router with VPN server option again.
- Apr 16, 2020Retired_Member
