PeteDin206
Sep 08, 2022Aspirant
Replacing BR200 with SXR80
So after the BR200 debacle I am begrudgingly replacing it with an SXR80 to function as my router. Behind it I have a full POE switch and a number of POE access points (WAX610s and wax630s) scattered a...
PeteDin206
Jan 18, 2023Aspirant
This all seemed to get corrected while rebuilding the network back in September, until the December firmware update on the SXR80. Since that update, my network constantly drops signal randomly. Of course my 90 day "support" (let's be honest that no one seems to actually provide support over the phone) ended right after this issue popped up.
Now I constantly loss connection across all devices on my network. This is likely my last shot at getting things fixed with Netgear as I'm already considering a chargeback on the SXR80 given it has basically become a unstable brick since the update. The rest of it I'll sell off just to fund something that actually works.
Current Network Build:
SXR80 set as router mode (4.2.3.102)
GS724TPP - POE Switch (2.0.8.11)
2x WAX630 (10.3.0.7)
1x WAX610 (10.3.0.7)
1xWAX610Y (10.3.0.7)
schumaku
Jan 19, 2023Guru - Experienced User
All links properly trunked carrying VLAN TAGs for each SSID and network?
- PeteDin206Jan 20, 2023Aspirant
From my basic understanding yes.
