BretD
Mar 27, 2019Administrator
Right-Size your Business WiFi with Multi-Satellite Orbi Pro Bundles
Originally Orbi Pro was available in a kit of 2 units – 1 Router and 1 Satellite with an option to add up to 5 additional satellites for a total of 1+6. Thanks to Orbi Pro's popularity we have created bundles that let you save money while also covering your entire business in blazing-fast Tri-Band Mesh WiFi. Your Orbi Pro deployments are flexible and easy since there is no need to pull any wires. Each satellite can either connect to each other and the router via an exclusive WiFi 5ghz band. Or if available - through an ethernet backhaul if desired. Orbi Pro satellite will need power via a standard 110-240v plug. Additionally, Orbi Pro Ceiling satellite can be powered via a dedicated PoE+ Ethernet port for power and or data.
What else do you get with the Orbi Pro system:
- High-Performance Business Mesh WiFi— Get WiFi coverage up to 17,500 square feet with seamless roaming to meet your business needs.
- Ideal for medium to large compounds such as warehouses, car dealerships, large retail shop
- Fast Internet speeds for all devices – The dedicated WiFi connection gives you the fastest and most consistent Internet speeds available, even as more devices connect.
- Quick & easy setup with the Insight app – Sync units together and manage/monitor your WiFi instantly from anywhere.
- Wireless communication between the Router and the Satellite. No need to run wires.
- Hardwire In – physically connect devices to the back of the units with the 4 available Ethernet LAN ports per satellite and the 3 Ethernet ports on the Router.
Available Orbi Pro devices and kits. Note: a minimum of 1 Orbi Pro router is needed for deployment of Orbi Satellites.
SKU |
Description |
Coverage |
Availability (as of Mar-27-2019 |
SRR60 |
1 Orbi Pro Router |
Up to 2,500 Sqft |
SRS60 |
1 Orbi Pro Satellite |
Add up to 2,500 Sqft |
SRK60 |
1 Router + 1 Satellite |
Up to 5,000 Sqft |
SRC60 |
Orbi Pro Ceiling Satellite |
RBS50Y |
Orbi Outdoor Satellite |
SRK60B03 |
1 Router + 2 Satellites |
Up to 7,500 Sqft |
SRK60B04 |
1 Router + 3 Satellites |
Up to 10,000 Sqft |
- Great innovation that would help a lot of people out there
1 Reply
- Jamie_LangerInitiateGreat innovation that would help a lot of people out there
