tecwerks's avatar
tecwerks
Nighthawk AX5 RAX29 Wifi Printer always busy
Since install of the router every device I try and print from comes up with Printer busy message. It's driving me insane. The printer worked flawlessly on my previous wifi router. I do not know where to turn to next. Anyone have any suggestions? Thanks
  • Received my HP printer with Ethernet port….happy to report that my printing issues are all resolved. Connected it to a Ethernet port on the router. Took me less than 5 min after opening the box. Time to throw my Brother Wi-Fi only printer into the garbage heap.
    • tecwerks's avatar
      tecwerks
      The printer shows up on all my other devices. I’ve gone through the setups multiple times. NETGEAR tech support was clueless. It was a Saturday though.
      • CrimpOn's avatar
        CrimpOn
        My printer has a web interface that can be accessed using the printer IP address.  Does the Brother printer have this feature?
        (Alas, I'm a "Windows person" and have no experience solving printer issues on Apple devices. Perhaps the printer support people would be a better resource?)
