LlamaLarry
Feb 17, 2021Luminary
Setting Static Route for Starlink
I live in a rural rea and just installed Starlink (yay), but seem to be having a problem setting the static route needed to access Dishy's statistics pages. Setup below: ATT LTE ...
- Feb 20, 2021
I removed the LB2120 from the equation and the static route worked right away:
IP: 192.168.100.0
Mask: 255.255.255.0
Gateway: The IP assigned to the Orbi by the ISP
Metric: 2
LlamaLarry
Feb 19, 2021Luminary
This is what I see when I run traceroute fro my Mac to my LB2120:
traceroute to 192.168.2.1 (192.168.2.1), 64 hops max, 52 byte packets
1 192.168.1.1 (192.168.1.1) 16.040 ms 2.043 ms 2.423 ms
2 192.168.2.1 (192.168.2.1) 4.517 ms 3.755 ms 3.133 ms
Trying to hit 192.168.100.1:
traceroute to 192.168.100.1 (192.168.100.1), 64 hops max, 52 byte packets
1 192.168.1.1 (192.168.1.1) 5.806 ms 2.361 ms 2.448 ms
2 100.64.0.1 (100.64.0.1) 4.270 ms 7.671 ms 3.637 ms
3 * * *
64 * * *
schumaku
Feb 19, 2021Guru - Experienced User
Looks like the traffic goes into the ISP (the satellite one?) 100.64.0.1 - which is a carrier grade NAT (CGN) address (not a problem). Possibly the device does act different for a direct connected computer - I guess that's the only choice to access the dish box.
- LlamaLarryFeb 19, 2021Luminary
The issue is that plenty of outher routers *do* set a static route to 192.168.100.1 so they can see the statistics and debug pages as well as allow the Starlink app to access the same.
The problem is that I have not seen a single Orbi/Orbi Pro report that it is working, so it is something in the way the Orbi handles/allows the settings.
https://www.reddit.com/r/Starlink/comments/jxkz1q/anyone_know_how_to_get_the_starlink_app_to_work/
https://www.reddit.com/r/Starlink/comments/jynhcy/router_setup_help/
- LlamaLarryFeb 20, 2021Luminary
IP: 192.168.100.0
Mask: 255.255.255.0
Metric: 2
- schumakuFeb 23, 2021Guru - Experienced User
LlamaLarry wrote:I removed the LB2120 from the equation...
If the Starlink local admin IP can be pinged but the other comunication does not come up this must have a different cause.
LlamaLarry wrote:...and the static route worked right away:
IP: 192.168.100.0
Mask: 255.255.255.0
Metric: 2
This is the default gateway either way - no need for a static route, assuming 192.168.100.0/24 does not exist on the LAN, this RFC1918 private subnet address is considered outside.
