LlamaLarry
Feb 17, 2021Luminary
Setting Static Route for Starlink
I live in a rural rea and just installed Starlink (yay), but seem to be having a problem setting the static route needed to access Dishy's statistics pages. Setup below: ATT LTE ...
- Feb 21, 2021
I removed the LB2120 from the equation and the static route worked right away:
IP: 192.168.100.0
Mask: 255.255.255.0
Gateway: The IP assigned to the Orbi by the ISP
Metric: 2
JohnD333
Mar 18, 2021Apprentice
3 of 3
Hoping you have found a solid work around.
LlamaLarry
Mar 18, 2021Luminary
Hopefully this works for you. First shot is the Advanced home:Advanced
Second is the static route I set (Advanced -> Advanced Settings -> Static Routes:
Static Route to DishyJust repalce the Gateway IP Address with the one in the Internet Port -> IP Address and you should be golden. Note, if Dishy reboots the route will likely be broken as your IP address changed. Just Edit the route with the new IP, Apply, and bingo.
I can't tell if my pics actually worked, here they are on imgur.
- jdowsMar 18, 2021Initiate
Thanks so much! Starlink App is now up and running. Much appreciated!
- LlamaLarryMar 18, 2021Luminary
My pleasure. I originally posted this thread to see if there was a way for us NOT to have to keep an eye on a shifting IP address, but it seems like the people in the know just hold firm to:
1. You don't even need to do it, it should work without it
2. The other routers that allow 0.0.0.0 as the route gateway IP are not following standards
3. What you're asking can't be done
:::Shrug::: This way works every single time on every single Orbi, so I don't know what to tell them. Without it we can't hit the stats via the phone app or website, this way we can. :::Shrug:::
- DishyApr 04, 2021TutorThanks! Worked perfectly for me on my RBR50.
- Apr 20, 2021Retired_Member
