BrainSuperGlue
Mar 29, 2022Tutor
Share printer on one VLAN with another VLAN : SXK30 Orbi Pro Wifi 6 Mini
Hi, Our SXK30 has two active VLANs / LANs. 1. Default (Admin) 192.168.1.x 20. Employee 192.168.20.x The company printer is on the Default (Admin) VLAN / LAN as 192.168.1.50 I want an emp...
JeraldM
Mar 31, 2022NETGEAR Employee Retired
Hi BrainSuperGlue,
You'd have to set a firewall rule that only allows one device in VLAN1 to be accessed by any VLANs though the SXK30 doesn't have that kind of configuration.
To start, were you able to access the printer even if you're in VLAN20?
If so, what you can try is to create a new VLAN, let's say "printer" VLAN and connect the printer to that VLAN. In this setup, both VLAN1 and VLAN20 can print to it then try enabling network isolation on those same VLANs as well.
Also, kindly check if the firmware is the latest version.
Please let us know how it goes.
JeraldM
NETGEAR Community Team
