JohanHolmberg
Oct 09, 2020Guide
[site blocked: ocsp2.globalsign.com] on SRR60
Hi!
I get [site blocked: ocsp2.globalsign.com] in my logfiles, preventing me to get access to services when using e.g. appltv and different apps. Also blocking other services like scrive.
I've read some threads about simular problems but havn't found a solution that works.
There is one tip about adding https service in "Blocked services" but that seams for me to do the opposite of what I want to achive?
I use block keywords but I have checked more then once that the blocked (but good sites) havn't the blocked keyword in the URL.
Any ideas where I can find more info about this or a solution?
Netgear Orbi Pro AC3000 (SRR60, SRS60) with FW 2.5.3.110
After I sent my log files I got the suggestion to remove the word "sex" from the "blocked keywords" list. After doing that I now don't experience any blocked sites.
Thank you BruceGuo for quick feedback and solution.
//Johan
Blocking ocsp2.globalsign.com will break the revocation status check by OCSP* of any https certificates signed by GlobalSign, and probably even more private PKIs making use of the GlobalSign OCSP service, so many https sites (and APIs or whatever cloud connectivity) will simply blocked or lowered in the security, too.
*Online Certificate Status Protocol (OCSP) is the Internet protocol used for obtaining the revocation status of an X.509 digital certificate.
No idea why Orbi Pro should block this site - considering there is no crappy Internet security stuff in the play - just on it's own.
Have any URLs in the blocking list on your Orbi Pro router?
Yes, that's my point - donno why they get blocked, feels random. I can see they get access from other local IP numbers. Looks like it's from apps on Apple TV that sometimes get blocked.
[site blocked: mailgun.scrive.com]
[site blocked: ocsp.int-x3.letsencrypt.org]
JohanHolmberg wrote:Yes, that's my point - donno why they get blocked, feels random.
More than that - just silly to block these... But then again, I still don't understand what exactly is blocking this - considering there are no crazy Internet Security "packages" on the Orbi Pro. BruceGuo
