Vintners
Jun 10, 2019Apprentice
Small Gated Community - Would Obi work to connect all the villas?
Kia ora, Looking for some advice on connecting our whole complex to the same network with Mesh. No separate passwords or usernames are needed. Coverage through-out the entire complex, includin...
- Aug 19, 2019
Guess what....?
It works AND I have 8 satellites working!!!!
Jun 10, 2019Guru - Experienced User
How many villa's/sized area are you trying to cover? I've seen the pro version with up to 5 satellites working. Not sure how large of an area and villa's you're trying to cover. Might have to move out of the consumer market and into the business class equipment. Or figure out a way to run the cabling.
- VintnersJun 10, 2019Apprentice
Hi,
There is a drone image attached. 14 villas across 2 hectares.
