Vintners
Jun 10, 2019Apprentice
Small Gated Community - Would Obi work to connect all the villas?
Kia ora, Looking for some advice on connecting our whole complex to the same network with Mesh. No separate passwords or usernames are needed. Coverage through-out the entire complex, includin...
- Aug 20, 2019
Guess what....?
It works AND I have 8 satellites working!!!!
Jun 11, 2019Guru - Experienced User
How many villa's/sized area are you trying to cover? I've seen the pro version with up to 5 satellites working. Not sure how large of an area and villa's you're trying to cover. Might have to move out of the consumer market and into the business class equipment. Or figure out a way to run the cabling.
Vintners
Jun 11, 2019Apprentice
Hi,
There is a drone image attached. 14 villas across 2 hectares.
- plemansJun 11, 2019Guru - Experienced UserHate to be a pessimist but i don't think your going to get that working all wireless. That's too much distance. You'll need some type of ethernet or coaxial backhaul.
- VintnersAug 20, 2019Apprentice
Guess what....?
- plemansAug 20, 2019Guru - Experienced User
Glad to hear it works. Were you able to get it done wirelessly or did you figure out a wired backhaul? I've seen the consumer used with 6 devices but never 8. I'm curious what speeds you're getting in each villa in comparison with what you pay?
