Juancito70
Dec 05, 2021Follower
Solid Red led (No Network) RAX45
Good Evening, hope all is well. I purchased my router few months ago and was loving it. My ISP is Comcrap. In combination with the router, I am using nighthawk cm1200 modem. I am the owner of a s...
Dec 06, 2021Guru - Experienced User
One thing I'd check. I notice that you have the cm1200 at your office. The CM1200 has 4x ethernet ports but because of comcast and how they operate, only 1 device can be connected to the cm1200 at a time.
So try powering off the cm1200 and the router. disconnect everything from both. Then power on the cm1200 and give it a couple minutes. then connect the router to port 1 on the cm1200 and power the router on. Then try settig up the router.
