2fatpugs
Dec 14, 2022Tutor
Specify 2.4GHz for vlan
Hi,
I have several devices that are not compatible with access points the broadcast both 2.4 and 5 ghz signals. Is it possible to create a vlan for them and assign it only broadcast at 2.4 ghz?
I have the SXK80 system.
Thanks in advance!
What's the point? You don't have to worry about the compatibility: Client's not supporting 5 GHz band won't care about that other band.
- 2fatpugsTutor
I am not sure about the specifics on why it can't handle both 2.4 and 5 and this is what is from the manufacturer. I tested and it is true, if I turn off the 5GHz antenna, the devices connect but once I turn it back on, it won't.
NOTE: Device only works on 2.4Ghz networks. (Device will not work on 5Ghz
networks or networks that use 2.4Ghz and 5Hz frequencies simultaneously. If your
wifi network does not segregate the 2.4Ghz wireless frequency, Bluetooth will be the only connection option)- 2fatpugsTutor
OK I found my own solution. In the Wireless setting you can break out the Antennas to separate SSID.
