iaeon
Mar 02, 2024Aspirant
SRK60 compatible satellites
Not sure I am in the right place - but I am trying to find out which Netgear Orbi satellites are compatible with an SRK60 Seems really difficult to find this information on the Netgear site. ...
michaelkenward
Mar 02, 2024Guru - Experienced User
SRK60 is an SRR60 router with SRS60 satellites.
This should help:
Which Orbi Pro routers and satellites are compatible? - NETGEAR Support
iaeon
Thanks for that reply - The compatibility chart did not come up in searches I did.
It seems this is an 'end of life' product and SRS60 is hard to find. RB50Y is compatible in extender mode only according to the chart. What does that mean in practical terms? A bit of a performance hit is OK so long as one can still move devices easily around the mesh network without having to select the access point once logged in.
Thanks for your help.
