travelmate81
Apr 23, 2022Follower
SRR60 - On power outage after a reboot - Devices not able to connect the router
I have a SRR60 with 5 satalites and around 80 devices connected. I don't recall having this problem in the past, I believe it is related to one of the latest firmware updates I've done. Descript...
DaneA
May 12, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Is the SRR60 directly plugged to an AC outlet? If yes, it would be best if its plugged to a UPS.
What is the current firmware version of the SRR60? If ever its not yet the latest version, I suggest you to update it then observe if the same problem will occur. The latest SRR60 firmware is v2.7.0.122 and you can download it here.
DaneA
NETGEAR Community Team
