NomadTanker
Jan 20, 2019Tutor
SRR60 Orbi Pro - Facebook wifi option not working
I have the newest firmware. The manual says I should be able to add facebook wifi. I see the option under the guest portal. However when I check mark facebook wifi. The button to add page does nothing once clicked.
idea's?
NomadTanker I used your terms and condition and could see correctly.
- RaghuHRNETGEAR Expert
Hi NomadTanker
You need to click on Apply button after you click on Facbook Wi-Fi . Then Add page button will be enabled. Please confirm have you done this or not?
Thanks,
Raghu
NomadTanker Could you please add the screen where you are trying to configure local Authentication mode? Is there any error when you try to customize the logo or use terms of service?
Thanks,
Raghu
