ButterflyGirl
Dec 01, 2019Aspirant
SRR60 ORBI Pro router enable bandwidth per SSID
Greetings, In the ORBI Pro setup, running firmware V2.4.2.106, under the Wireless 2 tab, there is a Bandwidth per SSDI section. There is a checkbox to turn it on and the 3 wireless networks shown on...
- Dec 27, 2019
Hi ButterflyGirl ,
Please refer to the user manual. http://www.downloads.netgear.com/files/GDC/SRK60/SRK60_UM_EN.pdf
We have implemented bandwidth management by prioritizing airtime based on SSID.
JohnC_V
Dec 04, 2019NETGEAR Employee Retired
Hi ButterflyGirl,
Welcome to our community! :)
As of now, Rate limiting is still not supported on Orbi Pro. You may share this idea in our Ideas Exchange for Business board in order for our engineering team to consider this feature on the next firmware release. But I cannot guarantee it.
John
NETGEAR Community Team
ButterflyGirl
Dec 16, 2019Aspirant
John,
Thanks for the quick reply & my apologies for the late response. I've been without services on and off since mid-November as AT&T has been slowly updating equipment.
Anyway, reading between the lines of your response, the check box for limiting bandwidth per SSID has not been implemented. Therefore, it doesn't matter if the box is checked or unchecked. Correct?
I appreciate your help.
ButterflySoul
- BruceGuoDec 27, 2019NETGEAR Expert
Hi ButterflyGirl ,
- ButterflyGirlJan 15, 2020Aspirant
Bruce,
Thanks for the document. I appreciate it. I'll be making the change later today.
Kindest Regards,
ButterflyGirl
