isaacx
Oct 30, 2022Aspirant
SRR60 Wireless backhaul configuration
I just got a second hand SRR60 plus three SRS60 mesh system. Reading the documentation it seems that the wireless backhaul runs in the 1733Mbps band instead of the 866Mbps band. I wanted to know if...
Oct 31, 2022Guru - Experienced User
No. You can't swap the backhaul/fronthaul.
I've asked the same before for those using a wired backhaul so they have the option of using the 4x4 backhaul as fronthaul.
