BooJangles
Jun 17, 2020Apprentice
SRS60 Device Access Control
SRR60 and 7 satellites (5 wired, 2 wireless) Hi all, Is it possible to control device access per satellite? For example, I have a satellite in a basement that has 3 devices physically plu...
- Jul 05, 2020
As far as I have check the Orbi Pro user manual here, it seems that there is no option to control device access per satellite.
DaneA
NETGEAR Community Team
DaneA
Jun 18, 2020NETGEAR Employee Retired
You may configure a MAC ACL (Access Control List) to prevent the specific laptop to connect to the SSID. To know how to configure this, kindly read pages 48-53 of the Orbi Pro user manual here.
DaneA
- BooJanglesJun 30, 2020ApprenticeThanks for that info.
Is there a way to control device access per satellite instead of the entire network though?
Thanks- DaneAJul 05, 2020NETGEAR Employee Retired
DaneA
- schumakuJul 05, 2020Guru - Experienced User
DaneA wrote:As far as I have check the Orbi Pro user manual here, it seems that there is no option to control device access per satellite.
And this makes perfect sense - this would require a lot of overhead and modifications of the radio firmware to become able to answer with "custom" 802.1k neighbor reports - one of the key features on all Mesh system designs - based on the MAC (BSSID) of the client where only MAC (BSSID) of neighbouring access points are reported - depending on the MAC allow resp. MAC deny lists on each individual access point.
