aalrashid
Oct 27, 2024Aspirant
SRS60 Ethernet only and turn off wifi
I have an srs60 satellite very close to the router since I need to to give Ethernet access to my home camera. However, I find that the satellite interferes with the main router given the close proximi...
- Oct 29, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 27, 2024Guru - Experienced User
30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
The wifi radios can not be disabled on Orbi MESH systems. Mesh is intended to be online 24/7 for wifi connections.
- aalrashidOct 27, 2024AspirantI can’t move any of the locations as I’m limited by wall ports. Any other ways such as buying 3rd party hardware?
- FURRYe38Oct 27, 2024Guru - Experienced User
Put in a longer LAN cable so you can move the SRS farther away from the SRR.
Check to see if there is a transmit power option on the SRR web page. If you see this, set it to 25% power. Mabybe under Advanced Tab/Advanced Settings/Wireless Settings?
How big is our home? Sq feet...
- aalrashidOct 27, 2024AspirantAbout 700. A long lan cable would be ugly as it will go through my living room so that’s not an option
