taurus1961
Dec 22, 2024Aspirant
SRR60 and SRS60 strange systems?
I have a SRR60 router (configurerd as AP) and two SRS satellites. I want to add an extra AP so i was wondering which one i could possibly buy. Netgear gives an compatibility sheet with a whole lot of systems but my SRR and SRS's are not between them.
I bought the set second hand but it seems that expand the set with another (then srs60) satellite is not done so i get the feeling that i had to watched out better before buy this set. I thought it's a Netgear Orbi so it's okay but know i had little regrets that i choose this model. Can someone confirm this? Or are there ways to expand the set i have?
Rgds, Paul
Hi taurus1961,
We’d greatly appreciate hearing your feedback letting us know if the information provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Have a lovely day,
RennaD
Netgear Team
- RennaDNETGEAR Moderator
Hi taurus1961,
SRR60 is an Orbi Pro device. The other satellites compatible to it, aside from the SRS60, are the SRC60 and RBS50Y. With RBS50Y only compatible in extender mode, which decreases performance. Please see link below:
https://kb.netgear.com/000065558/Which-Orbi-Pro-routers-and-satellites-are-compatible
Have a lovely day,
RennaD
Netgear Team- taurus1961Aspirant
This was the message which i will mark as accept solution
Hi taurus1961,
Have a lovely day,
RennaD
All clear now. I now know that my system is a Pro version and therefore less choice in satellites
Thanks for your support
rgds, Paul
