aalrashid
Oct 27, 2024Aspirant
SRS60 Ethernet only and turn off wifi
I have an srs60 satellite very close to the router since I need to to give Ethernet access to my home camera. However, I find that the satellite interferes with the main router given the close proximi...
- Oct 29, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
aalrashid
I can’t move any of the locations as I’m limited by wall ports. Any other ways such as buying 3rd party hardware?
Oct 27, 2024Guru - Experienced User
Put in a longer LAN cable so you can move the SRS farther away from the SRR.
Check to see if there is a transmit power option on the SRR web page. If you see this, set it to 25% power. Mabybe under Advanced Tab/Advanced Settings/Wireless Settings?
How big is our home? Sq feet...
- aalrashidOct 27, 2024AspirantAbout 700. A long lan cable would be ugly as it will go through my living room so that’s not an option
- FURRYe38Oct 28, 2024Guru - Experienced User
700 sq feet? If that's right then you don't need the SRS satellite. You only need just the main router unit.
Nothing could be installed up in the attic area from the router unit to the SRS?
Try a Power Line adapter set. But if the size of the home is 700sq feet then you don't need the SRS deployed.
- aalrashidOct 28, 2024AspirantNo no, my house is made from cement and isolation material so I need the satellite. Actually I have 5 satellites and some areas are still not covered. No actually I need the Ethernet connection to my home camera system and it’s installed in a place near the main router which explains the proximity of the satellite, so u wonder if there are other practical solutions
